Activity Forums Adobe Premiere Pro APPro >>Encore >> Encode failed after fw seconds??
  • APPro >>Encore >> Encode failed after fw seconds??
    Posted by Pushpanatha De silva on October 7, 2010 at 10:44 am
    Used Win XP with SP3. I have made several DVDs without any critical problem before using CS4 PPro & Encore in the same PC. Now it has given-up on me. Following things been done at present.
    CS4 is installed in C; and Project files saved in D:(separate drive)
    1. Removed all unwanted programs including Virus program, etc., This machine only has APPro CS4. All firewalls/virus program been disabled. The audio and video plays ok on time line of APProCS4 with little bit jerky (of course I was expecting this on a Pentium4). C;drive been formatted recently due to these problems and also defragmnted all drives. Made No screen savers working, no wall paper, Swap file >>virtual mem adjusted for D: , optimised the desktop by selecting,”adjust for best performance”
    2. APProCS4 project saved ok. It’s a 40minute program recorded on XDCAM EX1. Used File>>Adobe Dynamic Link >>Send to Encore ok..No errors.
    3.Used very short filenames and sub directories to save on Encore. Eg. file name used “HanOne”
    4.On Encore, Selecting End Action and TitleButton selections were done ok.
    5. When saved on Encore, file size was 2.48GB and 2.22GB were free. Audio:PCM,standard: PAL
    6. When on Encore, Choose File >> Build >> Disc (to make the DVD), after few seconds time it shows ” Encode Failed ” while start to Transcode .prproj(video) file in Build Progress Window.
    I would appreciate if you could suggest anymore things I have to try other than above.
    Costas Damianou replied 15 years, 3 months ago 2 Members · 1 Reply
  • Costas Damianou
    May 26, 2011 at 3:02 pm
    Hi
    I have just encountered the exact same problem. Has anyone got a solution for this?
