Activity Forums Adobe After Effects Expressions applyPreset Method Not finding Path
  • applyPreset Method Not finding Path
    Posted by Sean Franklin on October 26, 2015 at 6:17 pm
    Hi all,
    I’m writing a script where I’ll need to apply an animation preset to a group of layers. I have the exact path pasted into a path variable, and I believe everything else is correct, but it’s still saying “unable to call applyPreset” because of parameter 1.
    Any ideas on why this is not working?
    Also, is there a way to get script error messages on a bigger window somewhere other than just the info panel on the bottom of extend script?
    Below is part of the code.
    -Tim
    app.beginUndoGroup("Undo");
    var proj = app.project;
    var myLayers = app.project.items.layers;
    var items = app.project.items;
    var myComp, myLayer, myTime, myName;
    var presetPath = "C:\Program Files\Adobe\Adobe After Effects CC 2015\Support Files\Presets\Backgrounds\Apparition.ffx";
    var myPreset = File(presetPath);
    function creation(name,number,time,duration){
    this.name= name;
    this.number = number;
    this.time=time;
    this.duration = duration;
    //myName = name.toString;
    myComp = items.addComp(name, 1920,1080,1,duration,29.976);
    i = 0;
    var width = myComp.width;
    var height = myComp.height;
    var aspect = myComp.pixelAspect;
    var duration = duration-time;
    var myLayer = myComp.layers.addSolid([0,0,0],name,width,height,aspect,duration);
    myLayer.applyPreset(myPreset);
    creation("Begin",6,15,300);
    Tim Franklin
    Watchout System Programmer/Compositor – CBS Sports
    Freelance Visual Effects Artist/ Video Editor
    http://www.TimSFranklin.com
    Sean Franklin replied 10 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 26, 2015 at 6:22 pm
    Try specifying your path this way:
    “/C/Program Files/Adobe/Adobe After Effects CC 2015/Support Files/Presets/Backgrounds/Apparition.ffx”
    Dan
  • Sean Franklin
    October 26, 2015 at 6:30 pm
    Phew, I thought I was going crazy. Thanks so much for the quick reply on this, works perfectly!
    Tim Franklin
