Activity › Forums › Adobe Premiere Pro › Applying WARP stabilization to multiple clips
Posted by Dan Sakols on September 3, 2013 at 5:46 pmHi,
Warp stabilization takes a long time to process. Id like to apply it to multiple clips and let them run at night. How can I do this?thanks
dan
Tero Ahlfors replied 10 years, 8 months ago 5 Members · 8 Replies -
Ann Bens
September 3, 2013 at 6:24 pmYou have to apply the Warp to each clip.
You can use Paste Attributes but you will still have to click Analyze for each clip.
Use Ctrl + Down for selecting the next clip (CC only)———————————————–
Adobe Certified Expert Premiere Pro CS6
Adobe Community Professional -
Dan Sakols
September 3, 2013 at 7:01 pmWith CS6 can I queue them up to run together, or do I need to be there for each one to start?
thanks
dan -
Ann Bens
September 3, 2013 at 8:08 pmYou need to start each one but you can do that one after another.
Gwen Lindsey
September 3, 2013 at 8:52 pmI thought one could set up an adjustment layer rather than applying warp stabilizer to each clip. Is this not the case? This is for CS6.
Ann Bens
September 3, 2013 at 9:00 pmThe warp does not work on an adjustment layer, it needs to be on the clip itself. Try it.
Gwen Lindsey
September 3, 2013 at 9:10 pmThanks, I believe you. Happy to not waste time on this one. 🙂
Peter Gillberg
January 16, 2016 at 7:09 pmI see this ticket is over 2 years old. Now you can just nest the layers and then apply warp stabilizer on the nested sequence.
Peter Gillberg
Callouts Premium Stock Videos/Graphics/Music
https://www.Callouts.com -
Tero Ahlfors
January 16, 2016 at 8:15 pmOr edit first and only stabilize what you actually need to stabilize.
