Activity › Forums › Compression Techniques › Applying video filter to specific samples of frames.
Posted by Matt Kim on June 28, 2011 at 5:57 pmWhat is the best way to perform a specific video filter on random samples of frames?
At the moment I’ve found that the best way is to just use a -ss command along with the select command of the -vf option.
Thanks.
Matt Kim replied 15 years, 2 months ago 2 Members · 4 Replies -
Michael Rampe
July 4, 2011 at 12:57 am[matt kim] “What is the best way to perform a specific video filter on random samples of frames?
At the moment I’ve found that the best way is to just use a -ss command along with the select command of the -vf option.”
This seems like the best way to me as well….
Is there something that you cannot achieve using this method?
Michael
Matt Kim
July 4, 2011 at 3:41 amI was just wondering if there is a standard way of achieving this that I am not aware of, because I have just started using FFmpeg.
However, I still wish the -ss option was much faster because at the moment it is not running fast enough as I need to apply this option to thousands of videos.
I am aware that positioning the -ss option before the -i option may allow it to run faster. But it would seem that the videos that I am filtering are unable to do this as well. So at the moment the -ss option runs very slowly–about 1 sec per 1 minute.
Does anyone know of a specific way where I could speed up the execution time of the -ss option?
Matt Kim -
Michael Rampe
July 4, 2011 at 10:44 pm[matt kim] “I am aware that positioning the -ss option before the -i option may allow it to run faster. But it would seem that the videos that I am filtering are unable to do this as well. So at the moment the -ss option runs very slowly–about 1 sec per 1 minute.”
Putting the -ss option before -i skips through the I frames only and is not truly frame accurate. Putting it after the -i decodes every frame to find the exact one you set and is thus much slower.
What is your source codec?
Michael
Matt Kim
July 5, 2011 at 12:40 amWhen I put -ss before -i it starts running the cropdetect filter (i forgot to mention this is what I’m trying to run) at frame 0.
My source codec is H.264
