Activity Forums Adobe After Effects applying vfx on .mpeg
  • applying vfx on .mpeg
    Posted by Accountclosed on June 11, 2010 at 5:23 am
    I know this is probably a no-no but I’ve been capturing .mpeg HDV clips in premiere and using dynamic link apply vfx in AE. Now after capturing, should I be converting the .mpeg to something else (photo jpeg or something) before using dynamic link and modifying in AE?
    I’d like to save myself that step if possible, but if someone can advise me, I’d much appreciate it.
    thanks,
    Matt
    Michael Szalapski replied 16 years, 2 months ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    June 11, 2010 at 5:42 am
    As Dave mentions in his stock answer #1 (look for that in this forum) it is best to convert any compressed file to an uncompressed format before applying fx in AE, the reason being that compressed files do not have all the information in each frame of the footage and that can cause a bunch of problems. So- sorry, I do not think you can skip that step.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Michael Szalapski
    June 11, 2010 at 1:23 pm
    I happen to have Dave’s quote handy, but keep in mind, this only applies to earlier versions of AE. Adobe says that MPEG handling has been greatly improved. I haven’t had time to do decent tests for myself yet so I still follow my practice of rendering out a lossless file out of Premiere and using that in AE.
    Dave’s Stock Answer #1:
    If the footage you imported into AE is any kind of the following — footage in an HDV acquisition codec, MPEG1, MPEG2, mp4, m2t, H.261 or H.264 — you need to convert it to a different codec.
    These kinds of footage use temporal, or interframe compression. They have keyframes at regular intervals, containing complete frame information. However, the frames in between do NOT have complete information. Interframe codecs toss out duplicated information.
    In order to maintain peak rendering efficiency, AE needs complete information for each and every frame. But because these kinds of footage contain only partial information, AE freaks out, resulting in a wide variety of problems.
    And Adobe agreed. Again, this was for older versions of AE. CS5 shouldn’t have the same problems.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Accountclosed
    June 11, 2010 at 3:26 pm
    thanks dave. AE 10 is the same as AE in CS5 right?
  • Michael Szalapski
    June 11, 2010 at 7:27 pm
    lol @ “marketing weasels”
    – The Great Szalam
