Activity › Forums › VEGAS Pro › Applying transitions in Vegas 7…I need help
  • Applying transitions in Vegas 7…I need help
    Posted by Robert Champion on January 1, 2008 at 6:07 pm
    When I go to apply a transition into the timeline all I get is a black circle with a slash through it…All of the transitions are in the transitions window but it will not allow me to drag them into the timeline….What am I doing wrong here?
    -Robert
    Bill Maxwell replied 17 years, 6 months ago 5 Members · 6 Replies
  • Mike Kujbida
    January 1, 2008 at 6:47 pm
    First of all, a minor correction.
    Transitions are typically applied to the overlap of two consecutive events.
    To do this, drag event 2 over top of event 1 to create a dissolve (the default transition) between the two events.
    Now drag the desired transition on top of this dissolve to see the effect.
    To stop the Event FX window from coming up every time you do this, hold down the Shift key as you drag the transition over top of the overlap.
    To apply a transition to the beginning or end of a single event, place the cursor at the start/end of the event and drag it forwards/backwards to create a fade in/out.
    Now drag a transition over top of this fade.
  • Ralph Hajik
    January 2, 2008 at 4:39 am
    Hi Robert,
    Here’s a link that will get you started:
    Copy and paste into your browser. Look up Vegas Tutorials.
    https://www.vasst.com/
    Ralph Hajik
  • Robert Champion
    January 11, 2008 at 5:21 am
    Thanks guys
  • Bill Maxwell
    March 30, 2009 at 12:20 pm
    How do you slow down frames for video?
  • John Rofrano
    March 30, 2009 at 12:30 pm
    Either use Ctrl+Drag on the right edge of the event to slow the video down, or change the Playback rate in the Properties of the event, or if you need to slow down gradually, add a Velocity Envelope to the event. Either of these three methods can be used to slow down (or speed up) the video.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bill Maxwell
    March 31, 2009 at 4:02 am
    I knew it was easy when I did it before. I used the right click on the video track, went to properties and there is was.
    Thank you for the information.
    Bill
