Activity Forums Adobe After Effects applying tracker info to mask shape/position
  • applying tracker info to mask shape/position
    Posted by Hayyim Sanchez on September 13, 2005 at 6:33 pm
    hey all,
    ive recently transitioned to AE 6.5 from Commotion in order to support 16 bit files. Im wondering if AE has a simple way of applying trackers to masks, as in Commotion(scale,shape, and location)?
    any help would be greatly appreciated.
    Hayyim Sanchez
    Mylenium replied 21 years ago 2 Members · 1 Reply
  • Mylenium
    September 14, 2005 at 11:27 am
    Nope, you can’t track masks directly without third-party tools. All you can do is track the layers that holds the mask. In case you need to directly access masks, try to pick up Useful Things or Expression Effects, both of which are no longer officially around, though.
    Mylenium
