Activity Forums Maxon Cinema 4D applying Spring/Delay effector on controller keyframe does not work when it’s null, and the spring movement does not translate into the target object.
  • applying Spring/Delay effector on controller keyframe does not work when it’s null, and the spring movement does not translate into the target object.
    Posted by Maximilian Yuen on March 11, 2019 at 2:44 am
    I am using this car rig on a car animation:
    https://www.youtube.com/watch?v=2hdFz4Vv6tI
    so there is a controller that control body banking so I can animate those spring movement when the car do braking/turning.
    Problem is, any effector that I add for the spring movement does not apply to that null controller.
    So I change the null to a invisible cube and the spring movement work ONLY to itself, the actual car animation is still a hard keyframe with zero spring movement.
    any tips to add spring movement to a hard keyframe on null controller that will also apply to the target object?
    Maximilian Yuen replied 7 years, 5 months ago 1 Member · 1 Reply
  • Maximilian Yuen
    March 11, 2019 at 2:46 am
    I am using R18 if this matter.
    I am guessing it has to do with xpresso only read the keyframe instead of the actual movement of the controller that affect by effector…
