Activity Forums Apple Final Cut Pro Legacy Applying same effect to other footage
  • Applying same effect to other footage
    Posted by Beth Nilsson on June 2, 2011 at 4:27 pm
    Hi. I’m doing some color correcting on piece of footage. Now that I have it correct, I need to do the same to the rest of the footage in my video. I followed directions to put the video clip into the viewer and hit option f but it’s not saving to my favorites. I also tried to “make favorites” under the effects tab but it’s not saving. Is there a better way to get this effect onto all my clips. Thank you!
    Colin Mcquillan replied 15 years, 2 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 2, 2011 at 5:10 pm
    Sure, select the clip with the filters you want to copy and type cmd +c to copy it. Then select all the clips you want to add the filters to and right click on one of them to select “Paste Attributes”. Copy just the filters…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Colin Mcquillan
    June 5, 2011 at 9:18 am
    If the clip you want to copy from has multiple filters, and you only want to copy one or two of the filters over but not all, then double click the clip so it loads in the viewer an select the filters tab. Now hilite all the clips you want to add the filter(s) to (ctrl click each one). Now hilite the effect(s) you want to copy over and drag it to one of the hilited clips in the timeline. The effect(s) will now be on all of the selected clips.
    Colin McQuillan
    Vancouver, B.C.
    “Live, love, laugh and be happy.”
