Activity Forums Adobe After Effects applying lightning effect removes footage?
  • applying lightning effect removes footage?
    Posted by Dolphbean on November 10, 2007 at 1:36 pm
    I have an animation I created in C4D and have imported it into AE with an alpha channel. I now want to apply the horizontal lightning effect in AE to it. When i do this, the lightning appears and the footage below disappears.
    What is it that i am doing wrong?
    Many thanks in advance for your help.
    Regards,
    Dolph
    Dolphbean replied 18 years, 10 months ago 2 Members · 2 Replies
  • Mike Clasby
    November 11, 2007 at 7:33 pm
    Are you using Advanced Lightning? If so click the little “Composite On Original” box at the bottom of the plugin parameters.
  • Dolphbean
    November 11, 2007 at 9:48 pm
    many thanks. Problem solved!
