Activity Forums Boris FX Applying half tone effect to key channel only
  • Applying half tone effect to key channel only
    Posted by Jeffrey Moorbeck on January 13, 2014 at 9:48 pm
    Working on Media Composer 6.5.2 on PC (Windows 7) with BCC 8.0 effects. I have two video layers; the bottom layer is the background and the second, top layer is a keyed over graphic.
    When I apply the BCC half-tone effect to the second layer key, it effects both video layers. I only want it to effect the top layer.
    I’ve tried changing various parameters but still cannot obtain the correct result.
    Any suggestions? TIA
    Jeffrey Moorbeck
    Senior Editor
    Milwaukee Public Television
    James Macon replied 12 years, 8 months ago 2 Members · 1 Reply
  • James Macon
    January 15, 2014 at 8:31 pm
    Hi Jeffrey-
    Try holding the alt key when you apply the clip so you’re applying it to the Title Matte on your second layer. If that doesn’t work you can try using the Pixel Chooser parameter in Half Tone to apply only to the alpha channel.
