Activity › Forums › Adobe Premiere Pro › Applying global transitions
Posted by Hector Melendez on May 21, 2005 at 2:39 amMe again…
I finished a wedd. recap. The question is; How I apply a dissolve transition to all of the short clips w/o going one by one??? Same to slow motion… how I make all in slow??? There is any clue to do this fast??Thks in advance
Steven L. gotz replied 21 years, 4 months ago 2 Members · 7 Replies -
Steven L. gotz
May 21, 2005 at 6:04 amThe short clips can have the transition applied by using Automate to Sequence. If they are already on the sequence, Page Down gets to the next cut, and Ctrl-d applies the default transition.
To make them all slow motion, copy them to a new sequence and nest the sequence in their place. Then just time stretch it with the tool, or set the duration using the menu.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Hector Melendez
May 21, 2005 at 6:27 amThanks for the explanation… still need more details. How I get “Automate to Sequence”
“Then just time stretch it with the tool, or set the duration using the menu.” …. Which tool..How? Swear tried this and won’t work.
———–One more:
How I get roll/still titles over video?? -
Steven L. gotz
May 21, 2005 at 2:06 pmHector,
I highly recommend that you take a little time to read the manual, and perhaps invest in a training course. These are pretty basic questions.
To Automate to Sequence, select all of the clips in the project window and use the Twirl-Down menu (little triangle in the upper right corner of the project window) to select Automate to Sequence. You might want to place all of the clips in a new bin to make it easier to arrange them first. Then automate it.
For slow motion, you can put all of the clips in a new sequence and then select that sequence from the project window, and place it into the original sequence. You can use the Clip > Speed Duration menu, or you can use the Rate Stretch tool in the toolbox. It is the one made active by using the “X” as a shortcut key while the timeline is the active window. Just stretch the video to make it longer.
Titles are created using File > New > Title (F9) and to select Roll or Crawl, look in the upper left hand corner for Title Type.
Steven
Hector Melendez
May 22, 2005 at 3:52 amSteve, many thanks!
Yeah,I’m very crudito “rare/ rusty” in Premiere despite my 20 years in the video area professionally. I bought Total Training tutorials but hasn’t time to watch the videos. Only one so far… and understanding the English & at the same time the comprehensive tutorial is not a piece of cake. (I speak Spanish)
Worst is to find where is the answer to a specific doubt in all 7 or 9 discs (still un-openned)
I don’t know the rest but my concern is why those tutorials hasn’t language selection….million of people speak spanish and thousands are editors.Been working with Premiere less than 2 months.. this is my second wedding (with Premiere) when at the same time capturing/editing with ScreenPlay nle.
This is a piece of cake and do Almost the same as Premiere. This almost is why I’m entering in one editing PC integration…more flexibilityNow, will ckeck how I can overimpose a title in Premiere…(letters in top of the video) I loaded into the second video track but can’t find how?? >> opacity<?... Hector
Steven L. gotz
May 22, 2005 at 4:16 amWhen you create a title with the Title Designer, you save it and then from the project window, drag it into a track above the video. The transparency of the background is automatic.
Steven
Hector Melendez
May 22, 2005 at 5:05 amWow! never thoughtwas so easy thanks
and to take the opportunity you are online… sirone last question: why in the timeline, the dissolve xsitions is there but it won’t do nothing…(is anything correct) but in others works ok.
What it could be?
Steven L. gotz
May 22, 2005 at 6:34 amYou will have to provide more information for us to help you.
Steven
