Activity › Forums › Apple Final Cut Pro › Applying filters to roles?
  • Applying filters to roles?
    Posted by Jonathan White on September 26, 2011 at 12:13 pm
    Just wondering if it’s possible to apply audio filters to roles? I know I can highlight the different roles in the timeline but it doesn’t seem to select them.. what I would like to do (for example) is select every instance of a certain speaker and apply compression to them.. a bit like applying filters to a bus I think..
    Is this possible with roles yet??
    Johnny
    Seanchas Productions, Galway, Ireland
    Erik Lundberg replied 15 years ago 3 Members · 5 Replies
  • Erik Lundberg
    September 26, 2011 at 1:23 pm
    Not that I know of. This would be an excellent problem to solve via a Roles-submixer. Quite high on my wish list.
    Erik Lundberg
    Technical Director, Media Technology, University of Gothenburg, Sweden
  • Mark Morache
    September 26, 2011 at 5:15 pm
    I haven’t been able to use the roles “tab” to select clips, however, select the “clips” button in the timeline browser, right-click on the column headings, and turn on the “roles” column.
    Now you can type the roles name in the search field, and select the clips in the timeline index, and NOW you can add your effect to all of them at once.
    It’s not a bus filter, but you can make it work.
    FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Jonathan White
    September 27, 2011 at 8:40 am
    That works :-), thanks for that, I was trying to click on the header and sort by role (which doesn’t work) but using search is easy…
    j.
  • Jonathan White
    September 27, 2011 at 8:47 am
    Hmm, still not sure.. worked out if I double clip the effect it’s applied to all selected clips but how would I universally change parameters???
  • Erik Lundberg
    September 27, 2011 at 10:02 pm
    Wooo… Nice.
    Hm. If this is where things are heading…
    I would love even more sorting abilities in the timeline. And then some. For a complex project, searching for “media in a bin” might be tedious and much easier with keywording/metadata powers, but to operate clips in unison in a complex timeline based solely on criterias I chose. That will be awesome. If they go full circle with it.
    As posted elswehere, being able to adjust stacking orders by Roles would be really good. And most other sorting/filtering abilities that can be user controlled. Please Apple, the ones of you who would want to listen, more of that. And then some.
    And. Fix the broken stuff.
    Erik Lundberg
