Activity Forums Apple Final Cut Pro Legacy applying effect to one point of frame
  • applying effect to one point of frame
    Posted by Jack King on December 12, 2009 at 4:44 pm
    Hi there,
    i’ve had an ambitious idea, a little too beyond my scope as an editor at this point in time – so I need your help!
    i’ve shot a music video – some of the shots are of faces with projected images of faces being projected live on top of those faces. I want to use the bad tv plug in, and some other things – to make the projections on their faces look like old video – while leaving the rest of the video in tact.
    what tools would i use? i’ve been messing around with the 8-point garbage matte and am reluctant to keep persevering with it until i know whether or not there is a better alternative. How would some of you go about doing this? The images as they are look good, so this is just a little added something, hence it would need to be possible to make this look convincing otherwise its not worth spoiling some good images.
    thankyou! any help would be greatly appreciated AS ALWAYS.
    Jack 🙂
    Arnie Schlissel replied 16 years, 9 months ago 3 Members · 2 Replies
  • Kevin Monahan
    December 12, 2009 at 7:16 pm
    First step is to shoot them against blue screen. Can you do that?
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Arnie Schlissel
    December 12, 2009 at 9:57 pm
    [Jack King] “some of the shots are of faces with projected images of faces being projected live on top of those faces. I want to use the bad tv plug in, and some other things – to make the projections on their faces look like old video – while leaving the rest of the video in tact.”
    If I understand you, the video you’re editing already has this extra layer of video playing on the faces “baked in” to it in camera. And you want to add a filter to the layer of video playing on the faces. If that’s the case, there’s no way to do this without effecting the faces.
    If you want to create these kinds of effects in camera, then you need to add all of the filters to the projected video before you shoot.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
