applying edits in a nested sequence to its source clips..?
hi
i’m wondering if it’s possible to apply the edits I make in a nested sequence to the original video layers. For example, if I cut out 8 seconds in the middle of a nested sequence, is there any way to have final cut apply that same edit to each layer in the original sequence?thanks!
