Activity Forums Apple Final Cut Pro Legacy Applying distort to clips in the browser?
  • Jerry Hofmann
    March 22, 2009 at 11:13 am
    Well, you could put them all in a sequence, then paste attributes of the distortion, then drag these sequence clips back to the browser, but no way to apply motion effects to clips directly in the Browser.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Bret Williams
    March 22, 2009 at 5:40 pm
    Not completely true. If you imported 16:9 anamorphic as normal, it’s an easy fix. Simply show the anamorphic column, select all the clips, and right click the animorphic field and change the setting. That will change the distort attribute appropriately on all the clips.
