Activity › Forums › Apple Final Cut Pro Legacy › applying crossfade to multiple audio cuts at once
Posted by Tony Asimakopoulos on March 25, 2010 at 7:11 pmHello!
I know this is probably a basic question, but I can’t find the answer in the manual. I need to apply a simple 2-frame crossfade to all my audio cuts. There’s gotta be a way to select all the clips/edits and do them all at once. But how? 🙂
thanks!
TonyGarrick Enright replied 12 years, 5 months ago 5 Members · 9 Replies -
John Fishback
March 25, 2010 at 7:53 pmSelect all the clips then Command+Shift+T will apply the default audio fade between all clips.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Tony Asimakopoulos
March 25, 2010 at 8:29 pmThanks John,
Just tried it – no luck though! What could I be doing wrong?
Tony
John Fishback
March 25, 2010 at 9:20 pmSo sorry, it’s Command+Option+T.
John
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Tony Asimakopoulos
March 25, 2010 at 9:35 pmHi again John!
Thanks for your patience. It’s still not working for me…odd. Perhaps I’m selecting wrong? Is theer a way to select multipel clips so you see the “trim” color at each cut? Because it seems you can only apply a crossfade when you’re in trim mode, or whenthe “cut” itself is selected.
thx
Tony -
John Fishback
March 25, 2010 at 10:47 pmI think this only works in FCP 7. I used the single right-facing arrow selection tool (press T once) to select a bunch of clips and Cmd+Opt+T. You can select them however you like.
John
Matthew Currier
October 11, 2010 at 8:28 pmI was looking for a way to do the same thing. Have you figured out a way?
I’m using FCP 6.06
Tony Asimakopoulos
October 12, 2010 at 11:46 amSadly, I haven’t! Doesn’t seem to be a way…. let me know if you figure it out!
Rafal Kos
November 27, 2010 at 7:34 pmThis is easy. Select all your clips (COMMAND + A) in the timeline, then go to your browser, choose Effects > Video Transitions > Cross Dissolve, then drag “Cross Dissolve” onto the clips. Voila.
