Applying changes to all titles in timeline
Posted by Marc Morel on January 23, 2007 at 7:50 pmHi all,
I think I saw a similar post a while back but I can’t seem to find it anymore. Sorry if this has been covered before.
Is it possible to apply a change, say a color or a font change, to all titles in your NLE timeline. I have about 100 sub-titles on my graphics track (Media100) and I just want to be ready if the client comes in and says “It’s perfect, except I now want it in yellow”
Marc
Marc Morel replied 19 years, 7 months ago 5 Members · 6 Replies -
Chris Paul
January 23, 2007 at 11:08 pmTry this:
https://www.digital-heaven.co.uk/automotion/
Currently it only works in Motion- perhaps with the advent of FCP 5.1.2 they may also make an FCP version?
Chris Paul
POV -
Dave Beaty
January 25, 2007 at 12:58 pmI edited on Media 100 for many years before moving to FCPro a few years ago. AFAIK there is no way to change multiple graphics title clips at one time with Graffiti.
The only thing I can even think of, is since M100 uses stills rendered for realtime graphics when you hit “Apply” , it should be possible to set up an automatic batch in Photoshop to act on those realtime stills. If that worked, you could change the color ect, anything you could record as an action in Photoshop.
Animated graphics would be a whole other prob.
DB
Mark Frazier
January 25, 2007 at 5:29 pmI’ve had to do similar changes, and the quickest (and I know it’s not very quick) way I’ve found is to save the new font/color/etc. in the style pallet, and manually go in, select the text to change, and apply the new setting to the existing text. It’s mindless and time-consuming, I know. That’s why we bill our clients for changes like this.
Good luck, and let us know if you find a better way.
Mark
Peter Mcauley
January 25, 2007 at 5:36 pmHi Marc,
I know it doesn’t help you with your current situation where you have multiple subtitles on the graphics track that were generated with Graffiti, but in RED 4.1 we introduced a subtitle feature that will enable users to import .stl (EBU) generated subtitles which can be changed globally in one simple gesture. For example, you import the subtitle into the graphics track via RED 4.1 and then the client wants to change any style aspect of the title, say the font face or the color … you change the style in the style palette and then reimport the .stl file and all of the reimported titles have the style change. You can download the demo version from our site to check it out and it’ll work without a watermark for two weeks.
Cheers,
Peter.
Marc Morel
January 25, 2007 at 6:41 pmThank you both for your suggestions;
Mark – That’s pretty much the way I’ve been doing it. At least using the Style Palette the changes are consistent and no parameter gets forgotten the Nth time you apply the changes.
Peter – Sounds interesting but I generally get one big, badly translated MS word document I have to proofread, correct and cut up to match voice over text and timing. Already formatted sub-titles files . . . I can only wish.
Marc
