Activity Forums Apple Final Cut Pro Legacy Applying changes across all instances of a (sent) Final Cut Clip.
  • Applying changes across all instances of a (sent) Final Cut Clip.
    Posted by Brandon Hatch on July 5, 2011 at 4:15 pm
    Thank you in advance for any help! I am editing a series of corporate videos. I have gone through the transcript and cut them apart and put them into sequences according to the transcript given to me by the client.
    Because I used “Capture Now” when capturing, I have huge clips in the Final Cut browser for each tape.
    Since all the footage was taken in tape-long takes, the need for sound correction is pretty much the same across all the clips. So, from the browser (not the sequence), I sent these clips to soundtrack pro and removed the noise. Now, the corrected audio came back to the browser as an individual audio files that didn’t effect the audio in the sequences. Is there a way to modify the clips so that these modified clips are applied to all the clips I have already put into the sequences. I would like to avoid having to manually match the audio with each one. There are a lot of clips.
    Thank you for your help.
    Brandon
    Jerry Hofmann replied 15 years, 2 months ago 2 Members · 1 Reply
