Activity › Forums › Adobe After Effects › Applying automatic letters effects on a vector text object from AI
  • Applying automatic letters effects on a vector text object from AI
    Posted by Ran Trieger on August 3, 2009 at 9:56 am
    hello
    i am receiving some artwork from a client.
    he sends his designs and logos which are being made in AI.
    most of the time, to avoid having “fonts” problems, he converts
    the text into vector based objects.
    in AE, if i want to animate each letter, i have to first devide the
    letters in AI into layers, then to pre-comp it in AE, and then animate each layer.
    is there a way to apply those presets of text animations (Built in in after effects) to a layer (see attached picture) and hope that it will recognize the letters even if its vector based?
    do you have any other solution for how to animate those letters one by one in an easy way?… 🙂
    thanks!
    Dave Johnson replied 17 years, 1 month ago 3 Members · 4 Replies
  • Dave Johnson
    August 3, 2009 at 6:24 pm
    I now deal with this issue very frequently and this info may be helpful in understanding the options:
    It is a good practice to convert AI text to vectors to avoid font issues. The downside is that, when receiving artwork from designers only trained in using AI for print work, they typically don’t understand (and refuse to accept) the methods necessary to make AI artwork useful for other purposes (like motion graphics). So, all of the artwork will often be inside of one layer and/or randomly scattered among a bunch of layers all with names like “layer 1, layer 2”, which makes animating the letters of a word very difficult. The only solutions I’m aware of are to have all motion graphics designed by mograph designers, require/convince print designers who contribute artwork to do the following two things or do these things yourself with all the print artwork you receive:
    [1] put every piece of artwork you might need to animate on it’s own layer in AI (including individual letters of text)
    [2] spend an extra few seconds to give every AI layer a descriptive name since each of those seconds avoids wasted minutes or more in AE
    I’m still on CS3 so, unless this has changed in CS4, AE text animations only work with text layers. They can be used with Photoshop text layers by applying AE’s “convert to editable text” function, but I’m almost certain that doesn’t work with AI layers (99% certain … just didn’t double check before writing this). However, I consider having to convert PS text inside AE a sign that I should have created the text in AE in the first place since converting often creates a whole new set of issues with trying to retain all the stylization done in PS when it would’ve been easier to just do the same things in AE from the start.
    So, that was the long answer. The short answer is, if there’s an easier way to animate AI text in AE, I’d love to hear it too!
  • Adolfo Rozenfeld
    August 3, 2009 at 6:52 pm
    Bear in mind that if in AI you have all objects in a single layers, you can distribute them to separate layers by selecting the layer and in the Panel options menu choosing the “Release to layers (build) command.
    Text animation presets won’t work on AI text converted to outlines, because it’s not text anymore. In fact, even if not converted to outlines, it won’t work either – AI text can’t currently be converted to editable text in AE.
    Adolfo Rozenfeld · Adobe
  • Ran Trieger
    August 3, 2009 at 8:20 pm
    thanks guys.
    indeed, that was the (sad) result i got to as well…
    do you know any scripts or plugins that can seperate a layer in AE into its objects?
  • Dave Johnson
    August 3, 2009 at 9:00 pm
    I don’t know of plugins or scripts that do this, but I think the AI “release to layers (build)” command Adolfo mentioned is pretty close. As with any method, the results are still somewhat dependent on how the artwork is put together from the beginning so they often require some manual tweaking in order to get AI files good for AE work.
