Activity › Forums › Adobe Premiere Pro › Applying audio effects to one clip affects all, including other tracks
  • Applying audio effects to one clip affects all, including other tracks
    Posted by Duke Sweden on February 21, 2017 at 1:01 pm
    I had noticed previously that if I add effects from the audio mixer (treble, dynamics processing, etc.) to one clip, it affects all of the clips on that track. But yesterday I discovered that the effects also apply themselves to audio on other tracks as well.
    Other than adding the effects through the effects control panel, is there a way to do it without having all audio tracks affected?
    Duke Sweden replied 9 years, 7 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    February 21, 2017 at 1:29 pm
    If you add effects in the audio mixer the effects are track based not clip based and if you put an effect on the master track it will affect everything. These are useful for adding effects to certain submixes and loudness monitoring submixes/master mix using the loudness radar effect. If you want to add an effect to a single clip then drag it on the timeline.
  • Duke Sweden
    February 21, 2017 at 1:55 pm
    Just as I suspected. Cheers.
