Activity Forums Adobe After Effects Applying an effect to a roto brushed area
  • Applying an effect to a roto brushed area
    Posted by Martin Robbins on May 17, 2012 at 11:52 am
    I have used the roto brush to select a section of my video which is 10 seconds long. I just want to reduce the brightness on this particular area, and leave the rest of the video as it is. The process I have currently gone through is:
    Roto brush
    Duplicate
    Remove Roto brush on bottom layer
    Select top layer
    Then add filter.
    However when I’m doing this, in the layer window, I can only see the roto-brushed area, which appears to be changing. but it’s applying the filter to all. In the footage window I can see the whole shot, but no changes are being applied.
    Any suggestions as to what I’m doing wrong?
    Martin Robbins replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
