Activity Forums Adobe After Effects Expressions Applying an effect to a 3D (collapsed) layer makes it 2D
  • Ben G unguren
    January 3, 2012 at 10:41 pm
    For a temporary fix, you can arrange your precomped layer in the correct 2D order (above the layer behind it, below the layer in front of it, i.e.). My guess is this will also prevent any intersections between layers above and beneath wherever you place the precomped layer in 2D as well….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
