Activity › Forums › Adobe After Effects › Applying AE tracking data to Twixtor
Posted by Joel Landis on May 26, 2009 at 2:51 amSeems simple enough…How do I apply AE tracking data to a Twixtor tracking point? After using AE’s track, I can only select the layer I wish to apply the tracking data to. Actually, is it possible to apply the data to Twixtor?
thanks
Joel Landis replied 17 years, 4 months ago 2 Members · 4 Replies -
Pierre Jasmin
May 26, 2009 at 5:02 pmIn Twixtor PRO only, look at the bottom of the effects controls there is a Tracking Points Twirly
In doc (TwixtorProUsersManual.htm) in Twixtor folder see: Guiding Twixtor through the use of Track Points.
Pierre
Joel Landis
May 26, 2009 at 10:56 pmAh thanks. But now I’ve run into another problem. I’ve got two alpha channel precomps that I’m using for FG1 & FG2 mattes. The mattes cleared up the globbyniess (is that a word?) I was getting from hands moving while running. But now I am left with very distinct lines, about three pixels wide surrounding each of my mattes, tried feathering, reducing, inv matte shrink all with no success. Often these lines are darker in color. What could be the cause of this? Sloppy masking? Settings…?
thank you again.
Pierre Jasmin
May 26, 2009 at 11:57 pmJoel,
Not sure yet
If you download the Twixtor 4.5 sample projects tutorial file in:https://revisionfx.com/products/twixtor/help/#ae_compatible
I don’t see any black at layer edges
Hard to say what is going on? Anyway you can send to techsupport at revisionfx dot com a comp with a few successive frames (not the rendered frames, the source and the comp with the mattes) to see what is happening?
Pierre
Joel Landis
May 27, 2009 at 12:09 amMy apologies, I am getting black edges on my own footage/project. I’ll try sending something to tech.
