Activity › Forums › Apple Final Cut Pro Legacy › applying a scale change to several hundred individual frames/stills
  • applying a scale change to several hundred individual frames/stills
    Posted by Pierre on July 4, 2007 at 3:22 pm
    Hi everyone.
    I’m working on getting my time-lapse skills up to par for a project that’s right around the corner.
    So I’ve got several hundred individual still frames in my timeline and I’d like to apply a scale change to them (I’m getting some vignetting from ND filters).
    I don’t want to go in and scale each and every one. Can I change one and then apply to all?
    David Roth weiss replied 19 years, 3 months ago 3 Members · 4 Replies
  • Chris Poisson
    July 4, 2007 at 3:29 pm
    Just change the first one, select it and press command “C,” then select all the others and go to edit, paste attributes, select “basic motion,” and you’re done.
  • Pierre
    July 4, 2007 at 3:32 pm
    OMG that was easy. Thanks!
  • David Roth weiss
    July 4, 2007 at 3:33 pm
    [Michael Pierre] “I don’t want to go in and scale each and every one. Can I change one and then apply to all?”
    Absolutely!!! Apply the scale to a single still, then right click on that still and choose “copy,” then select the rest of the stills in the timeline, right click and choose “paste attributes” and check “basic motion” from the drop down menu that shows up.
    Good luck…
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • David Roth weiss
    July 4, 2007 at 3:35 pm
    And, he even included a keyboard command to boot…
    HAPPY 4th of JULY!!!
    David Roth Weiss
    Los Angeles
