Activity Forums Zaxwerks applying a map onto letters coming from the text generator
  • applying a map onto letters coming from the text generator
    Posted by Lucia Bastenhof on June 13, 2009 at 7:19 pm
    I try to solve the problem of applying One Single Material on different objects, both into Invigorator and Pro Animator.
    What I want to achieve is to apply ONE layer map which would appear spread onto the different letters.
    No problem with a .ai file, where objects, letters, have been grouped together.
    But I’m unable to achieve it with letters coming from the integrated text generator, both in Invigorator and ProAnimator.
    In both cases, the layer map (applied at one time on all letters selected) appears on each letter separately. Not spread on the entire group.
    In Invigorator, I checked, the letters, created together, belong to the same set.
    But how can I tell that I want One map for the whole set ????
    And how can I tell it into ProAnimator, where there are no set at all ???
    I’m looking for answers into the 2 user guides… nothing…. :-/
    Thanks for your help !! 🙂
    Lucia Bastenhof replied 17 years, 3 months ago 2 Members · 2 Replies
  • Edward Wu
    June 15, 2009 at 6:09 pm
    Hi Lucia,
    When creating 3D Text from the text generator, each character is created as an object, so the map will get applied onto each character. To get your material to map onto multiple objects at the same time, you will need to use the Illustrator grouping method that you have tried. So, the workaround is to use the “Create Outlines” command for all the words that you need to create in Illustrator, and then importing that into 3D Invigorator or ProAnimator. Then, you should be able to apply the Layer Map without any issues.
    Best,
    Edward
  • Lucia Bastenhof
    June 18, 2009 at 1:28 am
    Thank you Wu, it’s clear… Now I just need to be able to open an .ai file, as I say in another thread…. :-/
