Activity › Forums › Adobe After Effects › Apply Tracking Data to Masks?
Posted by Dan Oster on March 5, 2010 at 12:43 amHey, folks. I have some tracking points on a green screen that I need to mask out (stupid color choice), but the camera is hand-held and moving throughout the piece.
Is there a way to mask out each point, track the motion, and apply that data to my masks so they follow the tracking points? Then I would just need to adjust for when the actors cross in front. It would make my life a lot easier…
As always, thanks for ANY help!
– Dan
Dan Oster replied 16 years, 6 months ago 5 Members · 7 Replies -
Todd Kopriva
March 5, 2010 at 1:39 amYou can apply the tracking data to a solid-color layer with your masks applied and use that layer as a track matte.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Illya Laney
March 5, 2010 at 2:55 amOr you could clone out the tracking points.
Motion Design, Color, Editing
Simulated Wood Grain Cabinet Inc.
Bunim-Murray Productions -
Rob Webster
March 5, 2010 at 5:36 amCheck aescripts.com/tracker2mask. It seems like this script would do what you’re looking for. Or check out aescripts.com/maskstolayers. It seems like this would move a mask to a layer (as a normal solid, I suppose?) and you could then parent that layer to a null that has the tracking data. This layer could then be used as a track matte to mask out your tracking points.
Joey Foreman
March 5, 2010 at 6:57 amI believe the method that Todd stated is pretty much the standard; and deservedly so for its simplicity and effectiveness, the others involving unnecessary steps. No nulls or expressions needed.
A null would come in handy if you needed to match motion to a layer offset from the position of the tracker, and an expression would be the ticket if you wanted to give it some drag, gravity, random wiggle or whatnot.
Dan Oster
March 5, 2010 at 9:59 amThanks, gentlemen. This forum is always a great help!
Todd, can you take more through your suggestion in a bit more detail? This involves the TrkMat menu I assume?
– Dan
Todd Kopriva
March 5, 2010 at 3:03 pm> Todd, can you take more through your suggestion in a bit more detail? This involves the TrkMat menu I assume?
More information on track mattes in general and on rotoscoping (which this is a kind of):
“Track mattes and traveling mattes”
“Rotoscoping introduction and resources”
