Activity Forums Avid Media Composer Apply to all transitions (not dissolve)??
  • Apply to all transitions (not dissolve)??
    Posted by David Oulashian on February 2, 2006 at 6:46 pm
    Is there anyway to apply a transition to all cuts within a given In->Out point (similar to the way you can with dissolves) but with a custom or different transition?
    eg: I want to add 10 Slide In transitions in a row — how do I do this short of adding each one individually?
    David Oulashian
    PS — I’m on Adrenaline 1.6
    William Busby replied 20 years, 7 months ago 4 Members · 5 Replies
  • Chuck Reti
    February 3, 2006 at 3:39 am
    On a scene transition, create the effect you wish to use with the Effects Editor. Once it’s to your liking, drag the icon in the upper right of the editor box into a bin. You can even give it a useful name. Select the multiple scene transitions as you would do to apply multiple dissolves (shift-click, lasso). Double-cliek the effect you saved to the bin. Joy.
  • David Oulashian
    February 3, 2006 at 7:40 pm
    I don’t understand when you say:
    I have the custom transition effect and I can certainly drag it to a cut, but whenever I try to lasso a bunch of cuts, all I get is the indvidual clips being selected. Shift-Click doesn’t really do anything as well.
    Just to clarify, I am trying to apply custom transitions BETWEEN multiple clips, not custom effects TO multiple clips.
    David Oulashian
  • Dave Schweitzer
    February 3, 2006 at 10:34 pm
    I think the most foolproof way would be:
    set up your Slide In on one transition (the Avid CONCEAL effect category is what I’d use).
    Create a new bin called >>> Quick Transitions <<< make sure it's mixed case like my example. With your one effect selected, drag the icon from the effect editor to this bin. In the sequence, mark In-Out for all the transitions you want (just like the great way we can add dissolves to the in-out range). Make like you're going to add a dissolve, but when the Quick Transition box comes up, click on the topmost box as if to change to a Dip to color or Fade from Color, etc. At the bottom of what you're used to seeing there is now a separator line and all the transition effects which live in the Quick Transitions bin you just made. Any Avid transition can be applied this same familiar way. Enjoy!
  • David Oulashian
    February 3, 2006 at 11:08 pm
    Dave
    I here by dub you “king of all Avid knowledge”!
    That is exactly what I was looking for. I have been editing for 10 years and on the Avid since 2001 (Xpress and MediaComposer and now Adrenaline) and never knew that one — in fact I dont think anyone knows that one! AFAIK it is not in the manual!
    Thanks a lot!
    David Oulashian
  • William Busby
    February 4, 2006 at 10:05 am
    Just to add… you can save that bin anywhere you like & open it for any project. Also, once you open that bin, you can close it… it doesn’t need to stay open & whatever transitions you’ve saved to it are still available.
    Bill
