Activity › Forums › Adobe After Effects › Apply Text on a picket fence
Posted by Joseph Freeman iii on July 30, 2016 at 3:05 amI would like to apply a light text overlay to a grayish wooden fence and would like to avoid text in the spaces between the wooden planks. Using any of the blend settings, in the blend mode, doesn’t avoid text in the spaces.
The end result would be text only on the wood.
Thanks in advance for any assistance.Joseph Freeman iii replied 10 years, 1 month ago 2 Members · 6 Replies -
Kalleheikki Kannisto
July 30, 2016 at 7:30 amAdd subtract masks where the spaces are. Like a regular masks, but switch the mode from “Add” to “Subtract.”
Joseph Freeman iii
July 30, 2016 at 2:45 pmThank you for your quick response.
I had thought of using a mask but was hoping for an easier solution, failed to mention the text is parented to a camera tracker, which means there is much work to be done.
“No effort, no gain”
Again, thank you. -
July 31, 2016 at 3:25 pmIf the text layer is 3D and the shot has been tracked and the text properly placed on the surface of the fence, it should stick in place, including the masks.
Joseph Freeman iii
July 31, 2016 at 7:42 pmThanks for your follow-up.
I went back and applied the camera tracking positions to the text layer and all works just dandy.
When I added mask for each fence gap (5x), they drifted over time, even though the mask were on the text layer (3D layer)…
I even started over by creating the mask on the text layer before applying the 3d positions…no improvement.
I’m sure you’re right about the mask following the text, but I seem to be missing something??? Maybe the paths should have the Positions applied, if possible?
Again, thanks for your continued interest and suggestions.
August 1, 2016 at 6:49 amThe text must still drift, for the masks will stay firmly with the text.
You can turn off all other layers so that you have just the text and the camera and preview the masked text to verify this. If there is drift between the text and the mask, there’s something additional animated that shouldn’t be.
Joseph Freeman iii
August 2, 2016 at 2:07 pmI started from square one and everything works as you have indicated.
User error must have been the issue…
Thank you for your patience and suggestions.
