Activity Forums Boris FX Sapphire Apply Sapphire Light Rays to specific areas of the frame
  • Apply Sapphire Light Rays to specific areas of the frame
    Posted by Alex Bond on May 5, 2009 at 11:51 am
    I am trying to apply a Sapphire Light Ray effect to a shot but I don’t want it to affect the whole of the frame so I need to mask of some areas – I can’t quite work out how to do this, I can see the Mask option on the effect but how do I acutally DO it?
    Cheers
    Alex
    Avid Media Composer with Sapphire plugins
    1 Layer of Vision on V1
    Alex Bond replied 17 years, 4 months ago 2 Members · 2 Replies
  • Gary Oberbrunner
    May 5, 2009 at 1:11 pm
    Hi Alex; just paint or import a mask clip with the area you’re interested in (or use a Sapphire effect or whatever you like), put that mask on another layer below the layer of interest, then in Rays select Mask Use: 1 Track Below. Rays will only come out of the areas where the mask layer is white. (You can switch it to use black if you like.)
    Hope that helps;
    — Gary
  • Alex Bond
    May 5, 2009 at 2:17 pm
    Cheers Gary, will have a go at this when I get my edit suite back!
