Activity › Forums › DaVinci Resolve › “apply LUT to waveform” checkbox gone in V10?
Posted by Toby Tomkins on October 5, 2013 at 2:32 pmWhere is this!?
EDIT: I want to disable it! IE not have the LUT applied to the waveform!
Marc Wielage replied 9 years, 4 months ago 6 Members · 9 Replies -
Robert Houllahan
October 5, 2013 at 4:29 pmThat is pretty important if one is applying a display LUT
-Rob
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.com2X Resolve 18Tb and 24Tb Dual GTX580’s HD Telecine and 4K Film scanner plus a film lab.
Dwaine Maggart
October 5, 2013 at 10:58 pmAssuming you are using V10 Beta 2, in the Project Settings / Lookup Tables area, there are new selections for 1D and 3D Scopes LUTs. By default, these are set to “use Video Monitor Selection”. If you don’t want a LUT on the WFM, then select “No LUT selected” in the 1D and 3D Scopes LUT sections.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Toby Tomkins
October 5, 2013 at 11:10 pmIt’s greyed out. I can’t change it. It is fixed on ‘use video monitor selection’
Any ideas or is this a bug?
Dwaine Maggart
October 5, 2013 at 11:35 pmNo idea why it would be greyed out. Is anything else in the LUT area greyed out? What version of V10 are you using (DaVinci Resolve / About DaVinci Resolve). Mac or Windows? If you open a new project, is the Scope LUTS stuff greyed out?
Dwaine Maggart
Toby Tomkins
October 7, 2013 at 3:15 pmThis happens if you apply an old preset!!! Create new presets in Resolve 10!
Dmitry Kitsov
March 17, 2014 at 3:04 amLut options are grayed out id one chooses to “hide UI overlays to optimize playback” in settings.When that option is selected LUT is affecting the scopes. It would be nice if it didn’t
Marc Wielage
May 20, 2017 at 8:40 amThe best workarounds I can think of to avoid having a LUT affect the scopes would be two ideas:
1) use a LUT box to feed the monitor, so the LUT is just in the monitor and not in Resolve itself
2) use external scopes (like UltraScope or Scopebox), looped through the monitor, so you’re basically seeing the exact same signal displayed on the monitor — not the signal inside Resolve.
