Activity › Forums › Adobe Premiere Pro › Apply flicker removal to a total sequence
  • Apply flicker removal to a total sequence
    Posted by Tigr_ldy on March 21, 2007 at 9:07 pm
    I’m new and have put several stills into a sequence and now want to apply flicker removal to the entire timeline. How do I do that? If I group “field options” is greyed out, if I select the sequence “field options” is greyed out. Any suggestions would be greatly appreciated.
    Vince Becquiot replied 19 years, 6 months ago 3 Members · 2 Replies
  • Nathan Quattrini
    March 21, 2007 at 10:02 pm
    make another sequence, then drag and drop sequence 1 into that, then apply the flicker removal. In theory that should work for you
  • Vince Becquiot
    March 21, 2007 at 10:23 pm
    Just be aware that flicker removal is just another word for blur and will only take care of issues with thin lines and very sharp edges of large contrast ranges.
    You may want to preview all the stills and apply it to those stills that actually jump on a CRT. Most still should be fine as long as the saturation and luma are kept within legal specs. If they are not, you will be better off working with levels first.
    Cheers,
    Vince
