Activity Forums Apple Final Cut Pro Legacy Apply flash effect in Wide Screen
  • Apply flash effect in Wide Screen
    Posted by Daniel Neutzsky-wulff on March 28, 2012 at 2:27 pm
    I’m editing a trailer where I use some camera-flash effects. Using dip to color.
    However, it affects the ENTIRE screen, the black bars at the top and bottom since it’s widescreen. I won’t the flash effect ONLY to affect the picture itself not the black bars above and below.
    How do?
    Thanks in advance,
    Daniel
    Rafael Amador replied 14 years, 6 months ago 4 Members · 4 Replies
  • Juan Manuel
    March 28, 2012 at 2:51 pm
    Well, you can use a four point garbage matte to mask only the relevant part, but why are you using black bars to begin with? Just use a widescreen sequence
  • Dennis Leppell
    March 28, 2012 at 3:28 pm
    use the Too Much Too Soon flash frame transition plugin found here:
    https://www.mattias.nu/plugins/
    I also REALLY like the Impact flash found here:
    https://www.filmimpact.net/index.php/plugins/
    And yes, use a sequence that matches your footage dimensions.
  • Daniel Neutzsky-wulff
    March 28, 2012 at 4:06 pm
    All the material was converted to:
    Apple ProRes (HQ), 1.280 x 720
    Linear PCM, 32 bit big endian signed
    integer, 48000 Hz, Mono
    Sequence settings:
    1280 x 720 (Aspect Ratio HDTV 720p (16:9)
    Apple ProRess 422 (HQ)
    Those are my settings at the moment, I still get the black bars in the top and bottom,
    what am I doing wrong?
    Also, do you know any other plugins good for a horror trailer?
    Like inverted flashes and stuff?
    I know these are possible with the effects already built in, but the transitions you linked were pretty good.
  • Rafael Amador
    March 28, 2012 at 4:15 pm
    [Daniel Neutzsky-Wulff] “Those are my settings at the moment, I still get the black bars in the top and bottom,
    what am I doing wrong?”
    Select the footage in the time-line, and “Remove attributes: Basic motion + Distort.
    rafael
    http://www.nagavideo.com
