Activity Forums Adobe After Effects Apply filter to multiple layers
  • Apply filter to multiple layers
    Posted by Nomis on November 3, 2005 at 6:32 am
    Hi All,
    How can i apply the sample filter and keyframes to multiple layers? I have fifty layers in one comp that i want to effect the same way and then sequence. Is there a quicker way than effecting each one at a time?
    Thanks for your help. Could save me lot of work in the future.
    thanks
    Renato replied 20 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Nomis
    November 3, 2005 at 6:33 am
    sorry! spelling mistake. same filter not sample filter.
  • Renato
    November 3, 2005 at 8:29 am
    Hello,
    Select all layers in your comp, and click crtl+shift+C in order to put them in a Pre Comp. name the pre-comp whatever you want and thats all there is to it… anything done to the pre-comp will affect all layers that are inside (fx, keyframes, blendmodes, whatever)
    pre-composing is one of the most powerfull ways of working in after fx.. if you have time take a look at the after fx tutorials at the Cow, I remember seeing one about precomps (also know as nesting).. Its definetly worth a look..
    hope this helps..
    good luck
    renato
  • Andrew Yoole
    November 3, 2005 at 11:56 am
    Not sure if s! wants to precomp in this instance – he wants to apply keyframes to each layer and then re-position them, which is not possible in a precomping situation.
    If all your layers are currently aligned, the job is easy. Just set your filters and keyfames on one layer, select the keyframes and copy them, then select all the other layers together and choose paste. Then sequence the layers as required.
  • Renato
    November 3, 2005 at 1:19 pm
    sorry about that…I misunderstood his post..
    good luck anyway..
  • Nomis
    November 3, 2005 at 1:25 pm
    Hi – thanks guys, for your info.
    Andrew – followed your instuctions. So simple! feel stupid!
    Renato – Precomping is toooo good. You rock! feel stupid again!
    But will be able to fly though my job when i get back to it in the morning.
    Thanks guys!!!!!
    Thanks cow people!!!
  • Andrew Kramer
    November 3, 2005 at 2:18 pm
    Well one great way to do this is to create an “animation preset”
    Select all your effects and keyframes from the clip then open the “effects and presets” window then with all that stuff selected push the make new preset button from the bottom of the window and now you have an animation preset.
    select all your layers and place your cti at the start of the animation and drag out your preset.
    andrew
  • Renato
    November 3, 2005 at 3:33 pm
    hey s!
    no need to feel stupid..good to hear you figured it out..
    cheers
