Activity Forums Adobe Premiere Pro apply Field Options to multiple clips
  • apply Field Options to multiple clips
    Posted by Bfavre4 on May 12, 2005 at 4:52 am
    I can’t seem to be able to change Field Options to multiple clips. I have tons of titles in my 2-hour video, and they’re all on the same track. I selected them all with the Track Select tool, and went to Clip–>Video Options–>Field Options to enable Flicker Removal since that’s recommended for all titles. But Video Options is grayed out when multiple clips are selected. I used to able to apply anything to multiple clips in P6.5. Now with PPRO 1.5, do I have to select each of my 50 titles and enable Flicker Removal one by one?
    One other thing I can’t seem to figure out is how to get only 1 waveform of an audio clip to show. In P6.5, only 1 waveform showed in the clip on the timeline even if it was stereo. Now 2 waveforms are stacked on top of each other and squished vertically. Is there a way to only display one waveform like in P6.5 so I don’t have to make the track huge to see the waveform clearly?
    Thanks.
    Bfavre4 replied 21 years, 4 months ago 3 Members · 3 Replies
  • Steven L. gotz
    May 12, 2005 at 2:18 pm
    No joy today. There is currently no way to apply field options to multiple clips, and not even nesting them will help. Submit a feature request to Adobe.
    And, there is no way to show one waveform on a Stereo track. You can stretch the track to see both. or collapse it to see none at all.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • R. Hewitt
    May 12, 2005 at 2:29 pm
    Lacking feature already requested Steve. I discovered the problem after giving up on a repeatedly locking up Matrox RTX.100 card. What I found was the default setup for the driver that renders upper-field first regardless of TV format. When I later tried to edit previously captured clips, I noticed the fields were reversed – all 64 clips worth! Needless to say that took a long time to resolve!
  • Bfavre4
    May 12, 2005 at 9:05 pm
    Hmmm. Since all my titles are on the same track, I guess I could create a shortcut key to open Field Options and do that one title after another. But is there a shortcut key to actually select one title and then jump to the next title on the same track? Kind of like “tabbing” to each title along the track?
