Activity Forums VEGAS Pro Apply Fade to Unattached Object
  • Apply Fade to Unattached Object
    Posted by Tyson Onaga on March 4, 2009 at 4:40 pm
    Is there a command to add a Fade In/Out to a selected media object. Let’s say the object does NOT overlap another object in the track. I would like a (e.g. 2 second) Fade In/Out applied to the object without having to use the “drag Fade handle approach” on each end of the object. I.e., select the object and menu-command (or hot keys) and the fades are applied.
    Thanks in advance.
    – Tyson
    Jeremy Rasnic replied 17 years, 5 months ago 2 Members · 1 Reply
  • Jeremy Rasnic
    March 10, 2009 at 2:38 pm
    I know that Vasst’s UltimateS Pro allows you to do this via scripting, and I would think Excalibur would allow for the same.
    You could look around in the Vegas scripting forum on sonycreativesoftware.com and see if there is a script that allows for this for free.
    j razz
