Activity Forums Apple Final Cut Pro Legacy Apply Fade To All
  • Apply Fade To All
    Posted by Mick Haensler on September 2, 2010 at 5:09 pm
    Years ago I used to work on Speededit quite a bit and it had a nifty little shortcut that would allow you to put a crossfade between every clip on the timeline with one keystroke. Is there a way to do this in FCP??
    Mick Haensler
    Higher Ground Media
    Mick Haensler replied 16 years ago 3 Members · 3 Replies
  • Martyn Greswolde
    September 2, 2010 at 5:47 pm
    As long as you want to apply your default transition (normally set to cross fade) make sure your play line is right at the beginning of your sequence, select all and drag up to the timeline viewer and drop on overwrite with transition.
    Greswolde Photography
    http://www.greswolde.com
    I know little but I learn quickly!
  • Sterling Scott
    September 2, 2010 at 6:07 pm
    Just Select all clips and cmd T. Or map a single keyboard key for the add transition function.
  • Mick Haensler
    September 2, 2010 at 6:24 pm
    Thanks guys. Knew there had to be an easy way. Much appreciated.
    Mick Haensler
    Higher Ground Media
