Activity › Forums › Apple Final Cut Pro Legacy › apply effect to whole sequence
Posted by Jason W. miltt on June 17, 2005 at 12:04 pmif i want to apply an effect to the whole sequence is the only way to do it to put it into another sequence and apply it there?
in avid i remember you could create a new video track and apply effects to all video tracks below it.
how to do it in FC?
thanks.
Tom Wolsky replied 21 years, 3 months ago 7 Members · 6 Replies -
Matt Sandström
June 17, 2005 at 12:09 pm[ezichko] “if i want to apply an effect to the whole sequence is the only way to do it to put it into another sequence and apply it there?”
i believe that is the only way, or using the nest command which is basically the same thing, but what’s wrong with it? i prefer this to avid’s way for sure…
/matt
Bill
June 17, 2005 at 1:40 pmyou can drag and select everyhting and then with it all selected you can simply drag the effect right on it all. But I prefer the nest method personally.
Bret Williams
June 17, 2005 at 4:21 pmYeah. If you want to be able to turn the effect on and off, best to nest it. But FCP should institute some sort of effect layer akin to PS and AE.
Les Kaye
June 17, 2005 at 5:27 pm[Bret Williams] “FCP should institute some sort of effect layer akin to PS and AE.”
Or at the similar way it’s done in Avid (adding the effect to a track) -
Samuel Frazier
June 18, 2005 at 11:29 pmAgreed. Vegas also handles this well. Very easy to apply fx to clips, track, or whole project. All nles should have this ability.
Tom Wolsky
June 18, 2005 at 11:56 pmAvid works by rendering down layers. This is fine in a HD fully uncompressed format. In everything else it degrades the image quality. Avid’s system allows layers to be compressed and then recompressed multiple times. I hope FCP never adopts this solution, but remains, as most compositing applications do, with rendering only from the source media.
