Activity Forums Adobe After Effects Expressions Apply ease to selected keyframes using scripting
  • Apply ease to selected keyframes using scripting
    Posted by Andrew Sherman on February 28, 2023 at 12:31 pm
    I have a script that is not quite working yet; I want to apply easing to any selected keyframes, on any selected properties. Can you help me see where I’m going wrong?
    // Get the currently selected layer
    var selectedLayer = app.project.activeItem.selectedLayers[0];
    // Get the selected properties on the layer
    var selectedProperties = selectedLayer.selectedProperties;
    // Define easing
    var easeSlow = [new KeyframeEase(0, 90)];
    // Loop through the selected properties
    for (var i = 0; i < selectedProperties.length; i++) {
    // Get the selected keyframes on the property
    var selectedKeyframes = selectedProperties[i].selectedKeys;
    // Apply easing to each selected keyframe
    for (var j = 0; j < selectedKeyframes.length; j++) {
    var keyframeIndex = selectedKeyframes[j];
    selectedProperties[i].setTemporalEaseAtKey(keyframeIndex, easeSlow, easeSlow);
    Andrew Sherman replied 3 years, 6 months ago 2 Members · 3 Replies
  • Filip Vandueren
    February 28, 2023 at 3:12 pm
    Haven’t checked, but I think it’s because of the square brackets around your newly created Ease-object. Try:
    var easeSlow = new KeyframeEase(0, 90);
  • Andrew Sherman
    March 1, 2023 at 10:41 am
    Perfect – thank you!
  • Andrew Sherman
    March 1, 2023 at 10:49 am
    I’ve updated this now and it works nicely on things like opacity and separated position dimensions. I know how to update it to work for arrays (eg for scale), I just have not done that yet. However, When I try to run this easing script on something like keyframes on an effect slider, it gives me an error “undefined is not an object”. Do you know how I can get this to work for effect properties as well? It’s working correctly easing transform properties, but not effect properties.
    var selectedProperties = app.project.activeItem.selectedProperties;
    // Define easing
    selectedProperties[i].setTemporalEaseAtKey(keyframeIndex, [easeSlow], [easeSlow]);
