Activity › Forums › Apple Final Cut Pro › Apply Chroma Key at a specific area – Final Cut
Posted by Kurt Protrek on September 26, 2015 at 3:33 pmHi,
I am trying to apply the chroma key to a specific area in my screen.
The center of the scene has a fake TV with a green screen and around it more objects with green. When I apply the Keying on the scene I loose my green from everything. I would like only to apply it at a specific area, the fake TV. Is that possible?
Tony Solereno replied 8 years, 4 months ago 6 Members · 12 Replies -
Nicholas Zimmerman
September 26, 2015 at 4:55 pmWhat you want to do is use a thing called a garbage matte. If you’re on a version before 10.2 you should duplicate the clip and apply a mask on the top layer. this would also be the layer that you use the key on. If you’re on 10.2+ you can just click the shape button in the upper right of the effect in your inspector. This will allow you to add a shape mask that will restrict the key to it’s bounds. If the shot has movement than you can animate it with keyframes. If this is a common task for you than you should consider using SliceX/TrackX/DriveX (specifically SliceX or TrackX for this task). It offers tracking capabilities that can automate the animation of your mask.
________________________________________
NickZimmerman.net
________________________________________ -
Bret Williams
September 27, 2015 at 3:50 pmFor something like a TV it’s often easier to just use a corner pin distort and forget about the green screen altogether unless something passes in front of the TV.
Mark Suszko
September 28, 2015 at 3:33 pmI’m with Brent on this one, but also want to point out trackers exist in Apple Motion and work okay.
Bret Williams
September 28, 2015 at 4:09 pmThe new slice x, track x, drive x bundle from core melt is amazing.
Mark Suszko
September 28, 2015 at 9:15 pmNo doubt. I can’t yet afford those, but there is *some* of the same functionality in Motion. Not all, but”some”.
Kurt Protrek
October 2, 2015 at 3:53 pmHi Nicholas, thanks a lot for you replying. But I am still confused on how to do it. I have been trying to insert the mask, but it does not work.
I can add the mask on the “Color Correction”, but it does not let me to do it at Keying effect.
If I go to the mask effect and insert it, and insert the keyer. The keyer will still apply over the whole scene.
I have tried a lot of possibilities.
thanks!
Jeremy Garchow
October 2, 2015 at 7:12 pm -
Kurt Protrek
October 2, 2015 at 7:31 pm
