Activity Forums DaVinci Resolve Apply Camera Raw Settings to all clips in group?
  • Apply Camera Raw Settings to all clips in group?
    Posted by Francois Driessen on February 4, 2014 at 2:40 am
    Am I missing something..? But Camera Raw Master Settings does not ripple through groups in V10.1.1
    Is there a way that I can apply the same Camera Raw setting throughout my project to all the clips before I start grading? (Not using Project LUT)
    I need to decode using Clip, have BMD film Color space selected and have Highlight Recovery switched on. + have a second node with the BMD Film to 709 LUT.
    The Second node ripples through the group, but it seems like I have to manually apply the Raw Master Settings clip-by-clip from another Node Graph…
    Any ideas out there that could save me the 6 x1000 repetitive mouse-clicks… ?
    Francois
    FireTrigger Inc.
    https://firetrigger.com
    Francois Driessen replied 10 years, 5 months ago 3 Members · 5 Replies
  • Eddie Smith
    February 27, 2016 at 2:19 am
    I would love to know the solution to this as well. It’s driving me nuts!
  • Francois Driessen
    February 27, 2016 at 1:01 pm
    Are you still on Resolve10 (when this post was originally made) or is the same issue still unaddressed in V12?
    Francois
    FireTrigger Inc.
  • Rohit Gupta
    February 28, 2016 at 2:27 am
    Before you make any changes select all the clips in the thumbnail timeline in the Color page. After you change he settings, there is a button on bottom left of the palette which lets you apply the changes to all the clips.
  • Francois Driessen
    March 31, 2016 at 6:28 pm
    Hi, R
    I’ve tried to apply it as described with no luck. It defaults back the Project settings for handling raw. I need to use BMC Film colour space and that is not selectable from project settings as far as I can tell. Have you tested it with any other section than Decode Using Project ?
    Any other advice out there?
    -F
    Francois
    FireTrigger Inc.
  • Francois Driessen
    March 31, 2016 at 6:40 pm
    OK – Think I figured it out.
    NOTE: You cannot paste the grade info for Raw decoding from a still to the multiple clips selected. You have to paste it directly from a clip on the timeline. Raw decode settings seems to not be recorded in grabbing a Still.
    Francois
    FireTrigger Inc.
