Activity Forums Apple Final Cut Pro Legacy Apply blending to specific layers.
  • Apply blending to specific layers.
    Posted by Adam Hutchison on October 6, 2014 at 3:55 pm
    Hi there.
    I’ve tried searching everywhere, but I can’t find an answer for this within FCP.
    I’m trying to blend some burn stock with a text layer using the ‘darken’ blend mode, but I want the bottom layer to be unaffected by the blend. Is this possible?
    I know there are other, lengthier ways around this, but I would just like to know if you are able to select which specific layers can be blended, and whether you can exclude layers.
    Many thanks.
    Mark Suszko replied 11 years, 11 months ago 2 Members · 1 Reply
  • Mark Suszko
    October 7, 2014 at 3:02 pm
    I think the blend by nature affects all layers below it. What you might try is luma keying or revering the key.
