Activity Forums Adobe After Effects Apply Blending mode with slider?
  • Apply Blending mode with slider?
    Posted by Duca Simone luchini on April 28, 2017 at 7:53 am
    Hi everybody,
    there is a way to use only e certain percentage of blending mode, meybe using a slider?
    I mean, there are many effects which are a slider to set up a percentage of fx to apply or/and e percentage of blending mode (of the effect).
    But in AE, unfortunately…, blending mode can be 100 % or nothing applied.
    Suggestions?
    Walter Soyka replied 9 years, 4 months ago 2 Members · 3 Replies
  • Walter Soyka
    April 28, 2017 at 2:24 pm
    1) Duplicate the layer, set its blend mode as you like, and adjust its Opacity property.
    2) Use the CC Composite effect.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Duca Simone luchini
    April 29, 2017 at 7:20 am
    Many thanks Walter,
    so, if I’ve rightly understand these are two alternatives?
    I mean, you can use Opacity on the duplicated layer OR you can use CC Composite effect?
  • Walter Soyka
    April 29, 2017 at 8:57 am
    Yes, I proposed two ambiguously-numbered alternatives.
    Walter Soyka
