Activity › Forums › Adobe Premiere Pro › Apply an effect to all clips in the time line
Posted by William Mcqueen on June 24, 2005 at 5:17 pmIt may be obvious, but I don’t readily see it in the help file for 1.5… How can I automate applying the same effect to all clips in the timeline at the same time, and in the beginning?
Thanks so very much,
Bill in Toronto
David J replied 21 years, 3 months ago 4 Members · 7 Replies -
Alex Udell
June 24, 2005 at 5:20 pmCan you be more specific?
One solution may be nesting…
but it depends on keyframing…
Alex Udell
lead demo artist and trainer
PEI Graphic Technology http://www.profileeast.com
My Reel: https://alexudell.no-ip.biz
COMBUSTION EXCHANGE FTP: ftp://combustionexchange.no-ip
Logon: combustion_user
PW: learn -
William Mcqueen
June 24, 2005 at 5:26 pmI want to apply a time code reference effect(using DV date plug-in) to each clip in the time line so I can produce a reference tape/dvd for a colleague who writes our scripts.
Bill in Toronto
Alex Udell
June 24, 2005 at 5:56 pmSo you want to display source TC burn in?
In that case nesting will not work.
hmmmmm…..
Alex Udell
PW: learn -
David J
June 24, 2005 at 6:25 pmApply effect(s)to the first clip.
Copy the clip.
Select all the other clips you want to have the same effect(s) (track/multitrack tool?).
Edit/Paste Attributes.
Jim Gunn
June 27, 2005 at 4:41 amOne cannot cut and paste audio gain attributes to multiple clips in this manner in P Pro 1.5 I have found, unfortunately.
David J
June 27, 2005 at 4:36 pmBut you can use the audio mixer to alter the output volume of an entire track is you wish.
