Activity › Forums › Apple Motion › Apply a stroke to an animated alpha? NEED HELP!
  • Apply a stroke to an animated alpha? NEED HELP!
    Posted by Pippin on January 5, 2006 at 9:29 pm
    Hi all,
    I am trying to put a stroke around an actor that has an alpha all ready applied to him. I know that in Photoshop I would just select the alpha, and create a shape from the selection.
    Now the important part is that I need the stroke to follow the actor as the spot plays out… Any ideas, or are there any plug-ins I might purchase to help facilitate this action?
    Jim Kanter replied 20 years, 8 months ago 3 Members · 2 Replies
  • Doyle Rockwell
    January 5, 2006 at 11:28 pm
    Heya,
    You can use the Outer Glow filter. Just clamp it down so that the glow is a hard line, then pick your thickness and colors.
    Hope this helps. Good luck!
  • Jim Kanter
    January 6, 2006 at 5:04 am
    And if that doesn’t work, export a movie file of the alpha channe onlyl.
    Import the movie, place it under the actor element and scale it up slightly.
    Color to suit.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
