Activity › Forums › DVD Authoring › Application to check format of DVD (NTSC or PAL)
Posted by Chris Huggett on November 11, 2005 at 12:20 amhey guys
im after an application that can read a DVD that someone has made to see if its an NTSC disc or a PAL disc
Does anyone know of such a thing?
thanks
chrisEric Pautsch replied 20 years, 10 months ago 2 Members · 4 Replies -
Eric Pautsch
November 11, 2005 at 12:29 amhttps://www.mydvdedit.com/ its a MAC tool though
Check here to see if anything might be of help:
https://www.videohelp.com/tools?s=15#15
Chris Huggett
November 11, 2005 at 2:27 amHi Eric
i have just downloaded it and put my DVD in, but don’t know how to interpret it.
I went to a IFO screen (i think) and it showed a reolution of NTSC 720*540. But it also allowed me to change that to the PAL format. So i was a bit unsure if this was a setting or info about the disc.
Cheers
Chris -
Eric Pautsch
November 11, 2005 at 5:52 amIts reading the info from the TS folder. It if says NTSC, it certainly is.
Eric Pautsch
November 11, 2005 at 6:04 amWait…720×540? That seams kinda odd. Another thing to try just to make sure is MPEGStream Clip:
https://www.videohelp.com/tools?tool=MPEG_StreamClip
Select any VOB then under “FILE” select get stream info and see what it says
