Activity Forums Adobe After Effects “application has moved – repair?” when duplicating program.
  • “application has moved – repair?” when duplicating program.
    Posted by Scott Geersen on March 6, 2008 at 4:26 am
    hi guys,
    i often use the old trick of duplicating my program on the mac so i can run two copies at once. on the pc you use the -m switch to run multiple instances, on the mac it’s always worked to simply make a duplicate of the program.
    now with cs3, every time i open my dupe, i get the message “the application has moved blah blah… repair now?”.
    is cs3 operating differently to previous versions?
    is there a pain free way of running multiple instances?
    i need to render one project and work on another, or sometimes match settings between two projects. it’s just nice to have the option of running two at once.
    thanks,
    scott.
    Joe Hamilton replied 17 years, 9 months ago 2 Members · 1 Reply
  • Joe Hamilton
    December 15, 2008 at 9:42 am
    yea… i get that too. did you find a way to fix it?
