Activity Forums Compression Techniques AppleTV2 and PAL
  • AppleTV2 and PAL
    Posted by Peter Wood on July 17, 2012 at 10:44 am
    I feel like I’m wrestling with Compressor 4 on Mac…
    I’m editing in FCPX, a video which is PAL, 720×576 (Anamorphic), @25fps, interlaced.
    I want to encode it as H264, 720×576, 25fps, deinterlaced, 3000kbps bitrate, AAC 256k and, most importantly, play on AppleTV2. Basically, I just want to preserve as much as I can, without resizing etc.
    And my final thoughts, are that I cannot use Compressor. Which does seem a little strange, but I’d like to confirm I’m not missing something.
    I can start by saying, I already have some of my videos converted to the exact format I want (above) And they play fine on the AppleTV2. But the only way I could do it, was to have Compressor render DV, and then use Handbrake.
    Handbrake does what I want, compressor doesn’t. I just can’t understand why.
    When I choose “H264 for Apple Devices” and “AppleTV SD (Anamorphic)” in Compressor it seems to flat out reject any concept of the PAL video I have.
    It’s NTSC all the way… the only ratio I can choose is 720×480 or 720×461 etc. And letting it do it automatically will choose 720×480 and 30fps!
    I could go on with all the other settings I’ve tried but it all ends in tears 😉
    I cannot find any combination of output that will render the output I want.
    Is the reason for Compressor having such restrictive options, because it’s being ultra compatible (catering for iPhones etc) and is not as flexible as I need?
    Or is it that, technically speaking, the output I want isn’t supported, and that’s why Compressor won’t do it, but when I do it on Handbrake, it just happens to play?
    Peter Wood replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
