Activity › Forums › Apple Final Cut Pro Legacy › Apple Uncompressed no Alpha?
  • Apple Uncompressed no Alpha?
    Posted by Josh Weiss on February 13, 2006 at 8:46 pm
    I am working with the Apple Uncompressed 8 bit codec and was wondering why you can’t render out of say, after effects, with RGB + Alpha. Its rediculuous that you have to render two passes of everything to get an alpha. Am I missing something? Is there any way to fix this?
    Josh Weiss replied 20 years, 7 months ago 4 Members · 4 Replies
  • David Bogie
    February 13, 2006 at 9:40 pm
    There are only two codecs I know of that support alpha.
    Animation is one of them. Apple is not.
    bogiesan
  • John Pale
    February 14, 2006 at 3:53 am
    The Sheer Video Codec and the Microcosm Codecs offer Uncompressed with Alpha, but they are not free. If you are having problems using the Animation Codec, they might be worth a look. Neither will play without render within FCP.
    https://www.bitjazz.com/sheervideo/
    https://www.digitalanarchy.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=CT-MC
    Do not attempt to use the Avid Quicktime Codecs, which also support alpha, within FCP…they don’t work well…instability, crashing, etc. It has not been updated in many years.
    There are no codecs that support alpha that work with realtime editing. This includes Avid…remember, Avid does not edit with Quicktime, but rather converts Quicktime to OMF (splitting off the alpha) on import.
  • Itamar Kool
    February 14, 2006 at 10:20 am
    If you work in After Effects, you can add an output module that renders only the alpha. Then use that as a luma matte in FCP
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.3.9/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.02/AE 6.5 Pro
    http://www.koolendeanderen.nl
  • Josh Weiss
    February 14, 2006 at 1:19 pm
    Thanks, yeah I realize I can render a seperate alpha, but that really is an unneccesary step. I wish you could just do an embedded alpha with the uncompressed or some sort of plugin for it.
