Activity › Forums › Apple Final Cut Pro Legacy › Apple TV
Apple TV
Posted by Andy Roether 01 on December 15, 2010 at 6:36 pmDoes any one know if any version of the original Apple TV can loop video?
Shawn Feller replied 14 years, 12 months ago 7 Members · 12 Replies -
Andy Roether 01
December 16, 2010 at 2:38 amLoop as in repeat. My company wants to be able to loop a 20 to 30 minute video in a lobby all day long.
Thanks for your help.
Tony Brittan
December 16, 2010 at 3:36 amOpen the file in QuickTime and use the edit dropdown (I think that’s it…I’m on my iPhone right now…to select looping option. Save the file and sync back to ATV. Play it back and it will loop! Hope that’s what you’re lookin for. I use one to show my work at expos and stuff.
Tony Brittan
Owner – Island Shore Productions -
Zane Barker
December 16, 2010 at 3:58 am[Tony Brittan] ” Save the file and sync back to ATV”
Keep in mind the current AppleTV does not store any media on the device it self it is streaming only no syncing.
[Tony Brittan] “Open the file in QuickTime and use the edit dropdown”
I did that and synced it to my ipad and then attempted to stream it to the AppleTV and no looping. I also tried streaming it from iTunes on my mac after your little trick and again no looping.
**Hindsight is always 1080p**
Tony Brittan
December 16, 2010 at 4:05 amGood catch Zane! OP was asking about the original ATV. I haven’t a new one yet because I need to be able to keep my video work portable.
Tony Brittan
John Pale
December 16, 2010 at 4:10 amI am not in front of my AppleTV but I think you can create a video playlist in iTunes with your video repeated a ridiculous amount of times
Zane Barker
December 16, 2010 at 4:13 am[Tony Brittan] “OP was asking about the original AT”
Yea, I did pick up that he was talking about the original, I just figured I would clarify it for when people search the forum.
[Andy Roether 01] “Loop as in repeat. My company wants to be able to loop a 20 to 30 minute video in a lobby all day long.”
For something like that a Mac MIni might be a better solution.
[John Pale] “I am not in front of my AppleTV but I think you can create a video playlist in iTunes with your video repeated a ridiculous amount of times”
Both the new and the old version will not recognize video in playlists. Music playlists yes, playlists with video no.
John Pale
December 16, 2010 at 5:30 am[Zane Barker] “Both the new and the old version will not recognize video in playlists. Music playlists yes, playlists with video no.
“Actually, if you classify the video as a “music video” you can trick it into working.
File/Get Info/Options/Media Kind
Mark Petereit
December 16, 2010 at 3:04 pmYes, we have several original Apple TVs that we to loop our digital signage.
The trick is that you have to use QuickTime to set the video to loop before you sync it to your ATV.
We use Compressor to convert the video to Apple TV format. We then pull it up in QuickTime, press Command-L to set the looping flag, SAVE IT! then drag it into iTunes to sync.
I seem to recall that some videos gave us problems. We had to tell iTunes to convert them to Apple TV format, then pull the resulting file up in QuickTime to set the looping flag, save it, delete the original out of iTunes, re-import the new looping version, and sync to the ATV.
Yes, it can be a pain, but yes you absolutely CAN get it to work.
Shawn Feller
September 29, 2011 at 1:51 amTony,
Have you done this on the ATV 1G with exporting a power point to MOV file by chance?
I make a slideshow, setup transitions and times, tell it to loop and export it as a MOV which QT has not troubleplaying…but when I drag to iTunes it never shows up to move to the ATV 1G.
Any thoughts?
